JoLin
- Aug 18, 2007
- 5,146
Just purchased a 1985 Pro-Line WA that's been transported to my driveway. I don't know yet whether it'll be docked or trailered, but I want to buy a new trailer for it and I'm trying to research options before I go head to head with the dealer(s).
First, I want a pretty basic roller trailer. I've worked out a rough weight estimate as follows:
Basic Boat: 2200 lbs. (per the manufacturer)
Motor: '97 Johnson 175hp @ 375 lbs (per the manufacturer)
Motor Bracket - I figure 100 lbs.
Normal Fuel load- 40 gal, so call it 300 lbs. (the boat has either a 60- or 70-gal tank. can't remember off the top of my head)
Miscellaneous Junk and "safety factor" - 500 lbs.
1. Does a 3500 lb capacity estimate seem reasonable? That would put me in range of a single-axle trailer. I don't want to spring for a tandem unless I need to.
2. Of the major manufacturers, which provides the best value? The trailer I buy will be washed down and covered, and regularly maintained. I don't need fancy, I just need usable with enough reserve capacity to handle a trip once in awhile.
3. Roughly speaking, what'll it cost me?
All advice and guidance gratefully received.
