kill switch
KRK
I have a electric start 1975 evinrude 25hp. I have installed a push button start switch and I think I have it wired ok IT DOES WORK. But I want to put a kill switch and need some help. Does anyone know how to do this. The switch has 2 wires, I assume that I can ground one of the wires to the engine, But don't know were to connect the other wire. Thanks
almost retired again
Re: kill switch
Hi KRK,<br />If it has a power pack connect the other wire into the black wire with a yellow stripe.
KRK
Re: kill switch
Thanks A.R.A. , I don't think I have a powerpack. I have 4 wires coming out from under the flywheel and one of them is black with white stripe it plugs into a small pack and then some wires come from that box and go to the coils. One of those wires is black with yellow stripe. <br /> krk
Hooty
Re: kill switch
I'll bet that's it. Ground that wire and see if your'll engine will start.<br /><br />c/6<br /><br />Hooty
KRK
Re: kill switch
Hey Guy's, thanks I got the black and white wire and spliced it just before the coils plug and wired that one to the switch and grounded the other wire to the engine ground, from the switch and it seems to be working. THANKS AGAIN FOR THE HELP!!!! krk
