Kill switch.....How do you fit one?
Devilfish
Hi,<br /><br />is it easy to fit a kill switch to a '72 65Hp Evinrude?<br /><br />There is no switch on the boat at the moment, I just think it will be safer to have one.<br /><br />I assume it just goes inline with the ignition keyswitch on the remote unit?<br /><br /><br />Thanks<br /><br />Ian
Joe Reeves
Re: Kill switch.....How do you fit one?
On your engine which has Magneto Capacitance Discharge ignition, installing the kill switch is quite simple.<br /><br />One wire of the kill switch is to be connected to the Black/Yellow wire at the "M" ignition switch terminal. The other wire of the kill switch simply connects to ground. That's it.
Devilfish
Excellent. Should cause no problem at all then.<br /><br />Seems I am getting the hang of this a bit more now.<br />I understood all of the above.<br /><br /><br />Thans for all your help Joe
