kicker stalling out
cguettler
I have a 7.5 merc that is having issues. The motor fires up on the first pull, revs up and than stalls out. If I throtle up the motor after starting it, it will run at a high rpm for about 20 seconds before it cuts out. The motor will than not start. It acts like it is flooding out. If the motor sits for several minutes you can start it, but it will have the same problem. What gives.
There also seems to be gas leaking somewhere on the carb. Is it normal for gas to exit the choke area in the carb when the ball is pumped to many times. Thanks
