I have a 50hp main motor and a transom that almost will only accept that motor, not two. My boat from PO had a evinrude auxiliary motor bracket mounted on the far port side. I finally got my 5hp on and it does not reach water deep enough...i can move it a few holes doen. Then...my light 2 stroke 5hp must of been too heavy...cracks appeared in the bracket.
long story short..need a new bracket. And a good place to mount it.. if I use holes 6" lower, then when I raise, it'll store 6" higher... it will then it's skimming the water at 25mph. Manual tilting is tough and awkward because it will sit 2 ft behind where you can stand. Can anyone reccomend a long travel bracket and suggestions on how to ease manual tilt for storage when I use my kicker
https://ibb.co/QDtWsCB here's a pic of my boat before I found crack in bracket and removed the motor and bracket.
