kicker motor issues
deeg 1000
I am looking at buying an new 2006 deep v and it has a 115 opti and a 9.9 4 stroke kicker motor. Is there anything I should consider about having both before I buy. I don't really need the kicker but it comes with the boat and I got a good deal.
tashasdaddy
Re: kicker motor issues
just that it is a lot of added weight you don't need. you can always remove, store or sell.
deeg 1000
thanks for the reply, the dealer told me the kicker could not be removed because it came with the boat and it would leave holes in it if it was removed, seems to me there must be a way to do it?
JoLin
If the deal is really good, why not live with it for awhile before you decide to sell it off? Nice for trolling, and depending on where you do your boating, it can give you peace of mind, too. Granted, your rig is new, but a kicker can be a handy thing to have around.
That said, if you do decide to remove and sell it, the holes from the kicker's mounting bracket are likely all above the waterline. That gives you plenty of options for filling them, up to and including using bolts, washers and caulk to plug them.
tashasdaddy
the dealer told you that, to keep your from asking him to take it off, and reduce the price. sometimes their white lies, get a little on the grey side.
deeg 1000
thanks for all the info., really helped with my decision. I am getting the boat and now I know I have a good place to ask for advice.
DRIFTER_016
If you don't want/need the kicker just ship it to me, I won't charge you to take it off your hands. :D
jay_merrill
My suggestion is to keep the kicker - you never know when you will need it.
If you want a bit of an eye-opening education, carry a handheld marine VHF around for awhile and monitor Channel 16. While you won't hear all of the calls from the boats because of distance, the USCG transmitters are high power and their antennas are mounted on towers, so you will hear the responses.
Now that high horsepower outboards are common, and fuel prices are soaring, single engine installations on even fairly large boats are more common. As a result, I hear more and more responses by the USCG in regard to boaters being stranded due to engine failures. As was mentioned in another thread, the CG doesn't tow boats unless the occupants are in danger, so the next call by them is usually to request that another boater assist. This usually isn't a big deal in inland waters but if you run offshore to fish (as many people in my area do), it can be quite dangerous.
Having a kicker motor isn't going to get you home quickly in the event of a main engine failure, but it usually will get you home. Having the ability to handle your own situation is also a lot better than hoping someone like me is willing to burn up a bunch of $4.00 gasoline, to get you out of your predicament!
BTW, don't think you will be immune to engine problems just because the boat is new. I tow people with new, $20,000 motors in all of the time. While today's motors are great in a lot of ways, they are complicated and the smallest thing can disable them entirely.
CATransplant
I don't know, but I never go out on the water without an alternative method of propulsion. Even on my 12' aluminum boat, I have a trolling motor on the transom and a fully-charged battery on board anytime I'm on the water. I even have a pair of good oars in the boat, so I actually have three methods of propulsion. More than once, I've had to use the electric trolling motor to get back to the dock. Once, I even ran the battery down on that about half a mile from the ramp. The oars got me the rest of the way, and gave me a bit of exercise, to boot.
If you have just one large outboard on your boat, having that 9.9 hanging there could save you a lot of hassle someday, and maybe even your life. Just one tip: Use a separate, portable fuel tank for the kicker. Keep the fuel fresh and fire up the kicker each trip before you leave the dock. It won't run on contaminated fuel from your main tank any better than your big engine will, and if the main tank's empty it won't do any good either.
Besides, it's a lot less embarrassing to limp in with your kicker than to get towed in by some old white-haired geezer in a 12' aluminum boat. Really. :D
