I need some advice:
I've got a 1751 Polarcraft with a 50 hp. long shaft TLDI Nissan tiller motor that I use for the larger lakes here in Arkansas. However, most of my fishing is done on a smaller lake with a 10 hp. motor limit. My 'small lake' boat is powered by a 9.9 Nissan short shaft 4 stroke. I've thought about mounting the 9.9 on my 17 ft. boat as a 'kicker', and using it on the smaller lake, then removing it when I go to the bigger lakes. I could use the same gas tank, etc. Does this make sense, & if so what would be the best 'removable' mount to get, and would the short shaft 'kicker' work on the long shaft boat?
