1975 70HP Johnson 70ESL75B<br />Will not spin starter over with key switch. Checked neutral safety switch and it works fine (ohmed it as well as ensured it was not stuck). Changed starter solenoid. Motor starts fine by jumpering across solenoid and it will keep running. Checked switch with ohm meter and it seems to make and break contact when the key is turned all the way to start. Keyswitch will kill the motor when it is hot wired to start. Choke switch by ignition switch works with the key in the on position.<br />Getting voltage to solenoid when key is turned to start. Ran a complete bypass wire from the keyswitch to the solenoid bypassing the neutral safety switch with no change.<br />What's the chance it is the overheat device on the motor? Does it keep the starter from spinning or just kill the spark??<br />I have ran out of ideas. Need an expert please!!
