Keeping your engine cooler
stroker24
:cool: Is there any ways to help keep you engine cooler besides driving in the winter? It is water cooled only 2hp outboard evinrude
Shrike
Re: Keeping your engine cooler
The thermostat keeps your outboard at the correct temperature range unless something isn't working properly: Thermostat, water pump, clogging.
kenmyfam
Is it overheating currently ????
Haffiman
The 2 Hp does not have much cooling and no thermostat.
Depending on use and storage, every 5 year (max) change impeller, head-gasket and exhaust cover gasket.
If older than 5 yrs, lift off the powerhead and change the water tube rubber grommet.
