Hello everyone. Did a few searches for similar problems but no luck. I have 1988 3.7 mercruiser. I believe this is a ford engine. Here is what has happened so far.
Died and would not start. Sat overnight and started the next day but ran rough. Replaced Coil. Ran okay for about 15 minutes.
Switched focus to fuel. Change fuel pump and check all lines and filters
Still the same. Despite the fact that they were only 6 weeks old I replaced points and condenser. Problems went away.
Went for a boat ride which was about 1 hour long. Ran good. Approached dock and it died. Ended up placed condenser again. Boat seemed to run fine again.
Another 1 hour boat ride and started running rough again. Yet another condenser and runs good.
It seems something is blowing the condenser I assume?
Any thoughts ideas or suggestions are appreciated ... thanks
