Re: Keels on flat bottom boats
Like Cookin said, you need something to dig into the water when you turn. Otherwise you will just slide sideways. On welded alum boats, there is at least a 1" angle welded to the center of the boat covering the centerline weld where the two pieces of material that make up the bottom meet in the center.
If you have a wooden boat, I'd run at least a piece of 1x2 flat sided the full length of the bottom. If you want more, run another pair half way between the center line and the chine (area where the bottom meets the side), starting at the transom and running for 4' give or take. You don't need a big obtrusive keel like is on a displacement hull. Those things are there to accommodate and protect the prop.
If you ever water skied with a flat (trick) ski with no skeg, or tried to ride a disc with a flat bottom you know what we are talking about.
Mark
