Keel sealer and mounting anode to transom
srimshaw57
On the inside of the keel of my 22' Islander is this dark epoxy? that is partial loose. My question is if I break off the loose piece what do I use to fill it in?
Do you mount an anode on the painted surface of the transom or do you remove the paint?
JoLin
Not sure I understand this part. An anode is used to protect your metal parts. I have anodes mounted on my trim tabs and outdrives. Why mount one on the hull? That said, my boat has a 6" x 12" plate anode mounted on the outer transom. It's through-bolted and tied to the main 12V electrical grounding buss mounted on the inner transom. Is that what you're trying to do?
jbcurt00
Yours isnt an aluminum boat JoLin, OPs is, you NEVER ground anything electrical to the hull of an aluminum boat.
Srim, do you slip this boat or use it in salt?
srimshaw57
No this boat is trailer ,and only used in fresh water. PO had anode mounted on transom and connected to neg. of battery
smokeonthewater
For a freshwater trailered boat you don't need any anodes.
As far as loose epoxy... Pull it out if you want and be done with it...
There should be no need for anything to seal the keel... If you find that you have a leak then we'll help you fix it correctly but some sort of epoxy poured in the bottom of the boat isn't the way.
jbcurt00
Post a pix of the loose epoxy
If its up where the bow keel rises up from the bottom and is an odd ruddy brown smeg, its the factory seam sealer.
Does the boat leak? Or your just concerned about the brown stuff being loose?
Pix
Pix
Pix
alldodge
Attaching an anode to the negative terminal will do nothing to help. As before
JoLin
Okay, the name Islander didn't register with me as aluminum. Thanks for clarifying.
smokeonthewater
There are plenty of glass islanders.... Many manufacturers have sold boats called islanders.
I'm guessing he had another thread where he gave more info about the boat???
jbcurt00
Yep
Purchase a 1987 Starcraft 221V Islander, transom has to be replaced. have read different thread on I boats.Have read epoxy some say glue I'm in a quandary as to how to proceed.
And the description of dark epoxy along the keel flaking was a give away.
Not many glass boat questions are posed that way. But remembering his 87 SC post about the transom is how I knew.
smokeonthewater
Kinda figured that was the case...
I tried to look up his other thread(s) but the forum wouldn't show em to me for some reason.
