Keel fell off please help
Robertpel9
I bought a waterfront house on Lake Norman just north of Charlotte NC. The house came with a Catalina 25' sailboat with swing keel.
I think i learned why the owner just left the boat and title to me when he sold me the home. Lake norman is manmade and it looks like he left the keel down and when there was a bad drought here in 2007 the water got too low and the keel came off the bottom of the boat and is now laying in the clay on the botttom of the lake (Crrently about 5' of water.
How easy is it to fix this. The boat is in very nice shape otherwise. I know nothing about sailing but am willing to learn. I have a 23' Chris craft on a 10,000lb lift on my pier too so i could move that boat and bring the sailboat over and lift it out of the water if needed to repair this
Is this something worth exploring or is the boat worthless at this point. I am assuming i cannotuse it until this is repaired. The keel looks fine and is just lying under the boat needing to be attached
tschmidty
Re: Keel fell off please help
It's not particulalry easy since the keel weighs about 1500 lbs I understand. Here's a link to a install in a driveway.
http://sailincat.com/boating/C25_proj/C25_sk_install.htm
A very good resource here
http://www.catalina-capri-25s.org/forum/forum.asp?FORUM_ID=3
I wouldn't say the boat is worthless. Catalina 25's are kind of cool sailboats, but there are a lot of them around. You can get them for somewhere between 4-12K these days.
It could certainly be done, but would require some smarts in order to do it safely since there is considerable weight involved. PM me if you are really interested in tackling it and I might be able to come by and give some advice, but it would be an undertaking.
And no you can't use it without the keel except maybe to motor around but kind of pointless since you have a power boat already.
Mark SF
There are lots of Catalina 25s out there but not so many in nice condition. It has to be economic to fix the boat, even if you got a boatyard to do it.
First I would start by carefully examining the hull structure where the keel is mounted. I don't think it just "fell" off, it must have broken the mounting. It may just be the pivot hardware, or it could be the hull that failed where the keel is mounted. All fixable though - that's the great thing about fibreglass.
Aethelwulffe
I'm rained out here at the yard, so I shall throw in my idiotic $0.o2.
Parts of this suggestion do not apply if there is a Travel Lift around, But I am going to assume you don't have access to one. I am also assuming that you don't have a guy with a barge crane available. If you do, pay for it.
My Stupid Advice:
1. Assuming that you don't need to ballast out your hull to keep it stable enough, I would first drop the rig. A C25 isn't that hard to do, just rig some tackle to the lower shrouds so you can keep the stick in column as it is lowered, rig a jackpole from the base of the mast to the bow for your lowering tackle (look for a diagram if you don't know what this is, and enlist the help of a few buddies to do the job (as a first-timer) slowly and safely (and don't forget a cradle to lay the mast on as it nears horizontal!). At this point, you should have no trouble getting the boat hauled onto a trailer or travel lift.
2. Get everything (stuff) off the boat that you can.
3. If the boat is on a trailer and you have no access to a travel-lift or big forklift, you may lower the trailer tongue to the ground, but stands under the stern, then lift the tongue and use an a-frame or engine lift the bow a bit more (hopefully with the painter-ring on the bow). Now lower the tongue and pull the trailer out. Add all the stands or dunnage you can, keeping the keel area clear for action. Don't be scared of making some stands out of lumber if you need to. Get all Egyptian with it, and remember that you are going to hump around a 1500 lb chunk of iron in close proximity to the hull.
4. Get some lift bags. These can be some well made sail bags, USN seabags, or actual lift bags. I personally have used a dead inflatable dinghy for this exact same operation. You arn't going to bring the keel to the surface with the bag, just lift the forward end. This will allow you to tow the keel around to a boat ramp. Once at the ramp. have a wrecker winch the keel out of the water an onto his truck. Don't worry about freaking out the truck driver. They are used to dragging rolled vehicles up out of ditches, grounded boats, and boats the have come off trailers.
5. Get yourself a good selection of 4x4's to maker levers, fulcrums and the like with. A nice set of tackle and a come-along will help as well to get the keep under the boat and standing on-edge. You will be making a cradle trough to hold the keel vertical as it is jacked into the boat.
6. Have a nice new bronze keel pin ordered or turned. That is you problem, as the old one both suffered from electrolysis as well as decades of cast iron cutting into it. Especially if there is degradation of the pivot hole, you will want to put a bronze bushing in the hole to go against your new pin. Check the keel trunk for other damage, and check references for "flopper stoppers" made of nylon to prevent the keel from banging around and causing noise and wear in the future.
7. Once ready to receive your newly refurbished keel, your boat will appreciate a new pennant on your newly replaced/refurbished winch. I recommend using some 7/16' low stretch line instead of a stainless wire. It lasts much longer, and can be more easily examined for wear than wire.
8. Your newly faired keel can be lifted into place with a floor jack under the keel, just forward of the balance point. make sure your cradle has a wide base on the aft end to provide stability. After inserting the pin and adjusting the nylon flopper-stoppers, hook up your pennant and try it out. You are ready for a bottom job (or whatever you lake guys do).
Alternate methods for raising the keel:
1. Re-enforce three plastic drums pieces of wood taped lengthwise to spread load. Lash them together and affix a shackle lashed (heavily) around the middle with wide strapping. Hook tackle rated to 4500lb between the shackle and the keel. use ye-olde ski-boat to pull on the bitter end of the line running through the tackle. A triple block and becket set-up should allow you to simultaneously lift and tow the keel with a pretty small boat. When you slow down, the tackle will lower the keel, relieving the load should you need to adjust or if you get into trouble. A 55 gallon water drum (25 bucks new) will give you some 450lb of lift. You should be able to drag your keel around easily enough this way requiring only a couple of hundred pound of thrust. A cam-cleat on the tackle will allow you to lock off the keel after lifting. The barrels will probably get close to the surface once you get moving.
2. Use one barrel. Just put a single block or a steel ring on it as a fairlead. Run a heavy tow line from the keel, through the ring, and to the tow boat. With a big enough boat, you will be able to drag the keel along handily with just enough lift to lighten the forward end of the keel a bit. Make sure you have a smooth hard bottom and a marker bouy tied to the keel just in case.
It has stopped raining, and I am out of crackpot ideas.
Coho Ghost
Having owned a Cat 25 for 25 years, I know a fair amount about them. Since you have a swing keel boat that was free, less keel, I'd say you have a a great candidate to convert to a wing keel. The swing keels have always had a bad reputation for the supporting hardware failing, with horrific consequenses, and requiring a lot of frequent maintainence. I had a swing keel! Since your boat did not sink, there is probably no serious hull damage from loosing the keel.
A wing keel conversion is kind of a project, but quite doable by the average guy. Contact Catalina Direct, they sell the whole kit for the conversion. It ain't cheap, probably close to $3000.00 now, but your boat will be worth more that is would as a swing keel when the conversion is done.
Good luck,
Coho Ghost
up in WA. state
