Carb has been rebuilt. When I purchased the ski I was told it was hard cold starts without starting fluid and had to run the ski at half choke to run. I took the ski out for a test run and found that it was pretty much true except I got it to start after a bit without the start fluid since its bad for the engine. Before the carb rebuild today it would bog after half throttle and eventually let you get WOT. Now it will start but you have to run fine and still have to run it half choked. The carb was rebuilt fuel pump floats all gaskets etc. I have blown through the fuel lines and filters and all appear to be clear any ideas what to look for next?
