Kawasaki jet ski 650 for tubing ?
twintrades
Hey im going to get a 92' kawasaki 650 i think ts model.
Will it be enuf to pull around someone on a tube?
2 adult riders and 1 tuber.
also are these easy to fix if its shot ???? Im buying in the winter and cant drive it till spring...... :rolleyes:
Jeff Walkowiak
Re: Kawasaki jet ski 650 for tubing ?
if it is a 2 seat ski and your state requires an observer,, you can not tow any one with it because the person on the tube counts as a passenger also,, therefore it must be a 3 seater.. if your state allows a mirror in place of an observer then you are ok if you have the correct mirror
twintrades
So would i damage the jetski by having 2 on it and a tube being pulled ?
Its a 2 up to begin with.... ?
Jeff Walkowiak
nope- but it will tip over a lot and you get a ticket for being over capacity/ also be advised those are really not worth much so if you need to fix it you can exceed it's value pretty fast, especially if you had to actually pay someone for it in the first place. full retail value running and including a trailer is only 600 bucks,, those have only 52 hp engines.
