hi i just had my zxi carbs rebuilt, put her in the water hit the starter and just heard starter motor spinning no engine turn over. we tested the starter, and it is fine. the bendix or whatever gear is behind the fly wheel needs to come out and be replaced. my big question is if i use a used one is there any thing i need to lube it better so it wont stick or break not sure whats going in with this one b/c its stuck behind the fly wheel, and where do u get the special tools needed to pull the fly wheel to get access to that gear manual says flywheel puller and holder, and a rotor puller as well to pull the fly wheel, manual is not in front of me or id give the part #s to but i will if anyone thinks they would help, i have checked every site and no luck i m stuck. thanks for reading any imput is awesome
