Re: just tring to find out how to rig my boat
We had that same model, only we got ours back in '73 or '74. Great shallow-water boat (if it has teh kick-up rudder); would hold a bunch of people and pretty fast (at least I thought so until I got a Hobie
jib halyard goes to the left side of mast, main halyard cleast on the right. Jib sheets go right to the bullseyes on the cabin top and are held by the cam cleats.
Main sheet goes up from a knot at the end of the boom, down to a block on the back corner of the boat, across the stern to the other corner, around that block, then up to a block at the end of the boom, forward to a block at the middle of the boom, down to the centerboard trunk swivel cleat.
You also have a cunningham that goes on the front end of the boom and holds it down to the mast, and an outhaul that goes from the back lower corner of the sail (the clew) through an eye on the booom and forward to a cleat.
Note that on our boat, the block on the middle of the boom would have to be removed in order to use the boom roller furling (which we VERY seldom did).
Very simple rig; can't do much to trim or depower the sails, but simple to use
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Assume you have the reel to lower the centerboard; be careful and let that down slowly. Check that wire, too-that was the only piece we replaced in the first 10 years we had this boat.
