Re: just thinking out loud.....overheat warning on vintage ob's?
I guess I was mis-understood. Yes, anything is better than nothing. And sometimes, they actually work! I was just pointing out the false sense of security one gets by relying on the alarm. If the overhead condition comes on fairly gradually, they work fairly well. If it is a sudden overheat like from a spun impeller or plastic bag, it probably won't respond soon enough.
BTW, there is no way to test the system other than remove and heat up the sensor. Yes, you can test the alarm circuit outside of the sensor. But even that only says it is working at the moment, no guarantee about next time.
nwcove, your idea has merit. Go for it.
