Just replaced my vro pump...but found other issues.
echelonphoto
Just replaced my vro pump on my 2001 90 v4. I removed all the fairing to get better access....so far the motor runs great...I did put oil in the fuel tank also for insurance. Anyhow...I found some major corrosion on on part....can anyone tell me what this is and what I should do?P1080370.jpgP1080371.jpg
Chris1956
Re: Just replaced my vro pump...but found other issues.
Looks to be the upper motor mount. How about wirebrush, and spray it with Rustoleum Rusty Metal Primer. That is very good at stopping further rusting. Then use black topcoat.
echelonphoto
Thanks Chris...I will see how deep the damage is and follow up
boobie
Check it real good as that is a critical part of the mtr.
echelonphoto
Well basically I got off all the loose rust...there must have been some kind of vinyl coating on it which has failed...I peel it
back as far as I could an treated the area with rustolean primer.
