michael4124
- Jun 10, 2011
- 10
I purchased a 1983 Procraft 1650 V with a Mercury Blue Band 115Hp engine, serial number is 6200563. The boat had been sitting outside for at least a year and a half. When purchased engine would only turn over. After replacing head gasket, carburator gaskets and new floats. the engine will run but has a bad idle. I checked compression last night and all 6 cylinders were at 120. The engine will run roughly with a hose hooked up to it, forward and reverse both work. When i took the boat to the lake (wish i hadnt) the engine fired right up but wen i put it to gear it boggled down and quit. I have noticed from the bottom carburator that it is dripping gas when under pressure. I know very little about outboard motors and was wondering if anyone had any advice. I have read thru multiple posts about my issues and the majority check compression and spark. Has good compression i would assume with it being 120 and good spark. I am having trouble finding a service manual as most i am finding are for four cylinders and this one in particular is a inline 6. Any help would be nice?
