JUST MY LUCK???
catfish charlie
hey everyone ,<br /><br />thanks for all your help. my 78merc 140.. has a bad piston. i took off the inspection cover and the top of piston looks almost flat on one side and the top ring is gone.. what could have caused this. should i rebuild this engine or just go get another one.. what u think??
timmathis
Re: JUST MY LUCK???
A rebuild would be great and last you a long time.<br />It all depends what you want or can afford. If you buy new $1,000s and will last a long time also. Used $ ? how long it will last? thats up to you Charlie... Tim
andrewkafp
Re: JUST MY LUCK???
What likely caused it was a "Lean condition" in one carb which usually affects pairs of cylinders and usuaully the top ones. The motor seems to going fine, but the top carb has a lean mix, due to gum build-up. This causes excessive heat and eventual melt-down in the cylinder.
catfish charlie
Re: JUST MY LUCK???
i have rebuilt a car engine before but is the outboard ok for a noob to rebuild.. are special tools needed...
andrewkafp
Re: JUST MY LUCK???
Member.. ZMOZ 30892 is re-building his 1400 from an "Operator error" meltdown. He will be happy to give some tips. :D :D
