Hello, first post ever here and first time boat owner from MT. I have a few questions and figured this was the best place to start. I just bought a '76 Aristrocraft today for $600 bucks. This is my first boat purchase and I pretty much know absolutely nothing about boats.
Its white with red/white interior. I believe its the 19ft model, the VIN is ACL19V1072M76 if that tells anything. It has the 120HP Mercruiser with Mercruise outdrive. I pretty much bought it right on the spot cause it was only $600 bucks, which could be a good or bad thing. The outside is in great shape, and the interior looks really good except for the seats. The guy turned over the engine and it started up right away and he let it run for about 5-10 seconds and turned it off, didnt have it hooked up to water. The power tilt/trim doesnt seem to work at all, and the power control cable seems to be off.
Anyways first off I want a manual for the engine and drive. Which one would you recommend getting? Are there any particular things with this boat that I should look at/inspect that are known problems? What would be somethings that you would replace right away to tune up this thing?
I guess ill go from there and start reading these forums to get familiar with boating. Thanks in advance for any help. Derek
