Bill Adkins
- Sep 27, 2006
- 68
I have an 1971 1350 tower that starts, idles, pumps water out the telltale like it was a happy camper. Put it in the lake and for about 30-40 minutes it does everything really well. The boat just flies as it were, it should as its a bit small for that engine but after the described running time it will stall if you bring it back to idle. It will restart without too much difficulty but it wont take throttle after the event starts, it will just die with throttle. After it cools for a while it will start the cycle again.The fuel primer bulb is firm and seems to be ok. Could it be carbon on a reed valve? I had it dyno'ed and it is at spec for being at 7000 feet altitude. Perhaps there is someone on the board that remembers some old pain in the backside, anyway I hope so.
Bill Adkins
Bill Adkins
