Re: Just added a Hustler. Max mph question
You could try the "lightest" hole setting now like you are thinking to do, and compare, simple enough procedure. Just do one thing at a time, with the same prop, etc. I think you have the right methods in mind.
Ideally though some tuning to the tabs was done after installation. Did you note the top speed before and after tab installation? The tabs should have allowed the same top MPH as before, or maybe a slight gain according to Nauticus. When dialing in the tabs if the top speed went down then go to the next lighter mount setting and try again. Change the settings until MPH is the same as pre-tabs or as close as possible, all of this with the same load and prop. Each boat responds differently. If this tab dialin-in tuning was not done then "release" them until you are through with the prop tuning, then dial the tabs in again. Nauticus has a slick lever type mount available for this, so you do not have to tie them up or take them off.
If after all this, when dialing in the tabs, if the lowest setting causes measurably lower top MPH than pre-tab condition with same-same prop and load then sometimes the next lighter pistons may be more correct for the boat. Nauticus has all this info on their site, and also are just a phone call away for good advice.
