just a heads up if your thinking of installing a 350 vortec engine.
lime4x4
Today i started installing a 1998 chevy 350 vortec engine into a 86 boat. Everything was going good till i went to install the water pump.Turns a water pump from an engine with a stamped steele timing cover will not fit a vortec engine with the composite timing cover. So it was another run my local marine store to get the correct water pump
typhoon0003
Re: just a heads up if your thinking of installing a 350 vortec engine.
just cut the head off the one bolt in the way, it has a built in washer that will hold it fine. if you have to pull your timing cover you have bigger problems than one tough to remove bolt.
