Re: Junk????
bv,<br /><br />Neither of these is a BAD product. <br /><br />Boat: Walk around inside (a little heavy footed) and see if there are any soft spots in the floor. If they're there, you'll know.<br /><br />Engine: Check the compression. It should be within 10 psi. for all cylinders. Check the lower unit, after a sea trial, the lube should NOT be "milky" looking.
