I recently have been experiencing a problem with getting full rpm at WOT. The rpm rises to 4600-4700 and even though I have 1/4"-1/2" remaining throttle travel on the controls,as I increase throttle position, I get no increase in rpm. There is no change in sound, or bogging down, it just does not increase in rpm. No change in sound of the motor, etc. a couple of weeks ago the wot was 5500. Nothing on the boat has changed, prop etc.<br />I am wondering if I have a fuel filter clogged or something like this. <br />The prop is the same, bottom of the boat is clean, the load is the same (myself, (2) 1/2 tanks of fuel, etc.)<br /><br />Is it possible to just get a 5 gallon plastic tank and drop a 3/8" fuel line in and connect it directly to where the fuel filter is on the engine? I am thinking this would eliminate any upstream issues, ie: fuel/water seperator, fuel tank switch, hoses, etc.<br />Thanks in advance for any help
