Johnson won"t pull it's own weight??
baitfish
I have 1986 johnson 60hp. ran out of gas on trailor after about 20secs. or so? i replaced VRO pump now runs fine on the trailor but when i try to tack off just boggs! barely keeps running??? think its carbs but would like confermation from the people in the know.THANKS FOR ANY HELP!!USMC..HOOOORA!!!!
steelespike
Re: Johnson won"t pull it's own weight??
Youve got it,probably dirty carbs.Give em a rebuild.While your at it go through it from tank to carbs check clean and repair as required.
Hooty
When ya say you ran the boat on the trailer, I hope the trailer was backed into the water.<br /><br />c/6<br /><br />Hooty
baitfish
YO SPIKE THANKS FOR THE INFO!!!! SURE I'VE GOT A MANUAL!!!!!WOULD'NT WORK WITH OUT ONE!!
baitfish
YO! HOOTY,DO YOU REALY THINK I WOULD RUN MY MOTOR WITH OUT WATER!!!
OBJ
HEY!!!!!!!!!!!! USMC!!! Listen up!!!<br /><br />Sorry dude...was a zoomie at one time. Love to dig other branches.<br /><br />Check the manual about sync and link. This is where the throttle picks up in relationship to the throttle plates. <br /><br />Just another question, is yer' manual OEM or generic?
baitfish
YO!! OBJ, THANKS 4 TAKIN THE TIME 2 RESPOND! I THINK THE LINKAGE IS COOL! THE CARBS ARE PROBBALY AT FAULT! I'M GOING 2 REBUILD THEM TOMORROW! LET U KNOW HOW I MAKE OUT!!
