Johnson water pump
Stumpys
A quicky question before I call IBoats...<br /><br />I bought a water pump kit for my 1978 85 HP from IBoats. The parts finder said it took a 18-3393.<br /><br />On the plastic part of the water pump was different than what was on mine. Mine has a seal on the top and the one I got did not have a place for the seal. Everything else was perfect match. <br /><br />Now that I I put the lower end back on and connected the muffs... The pump works fine except that I have water coming out around the cavitation plate where the lower end bolts on.<br /><br />Is this a problem or gonna be problem??? Do I need to put the old one back on?<br /><br />I know that with my Merc, no seal was needed, but this is my first Johnson.<br /><br />Thanks as always...
OBJ
Re: Johnson water pump
Having water coming out in that area is common when using muffs Stumpy. Nothing to worry about.
Stumpys
I figured that using the muffs is putting a lot of pressure where it is not suppose to be.<br /><br />Man, I'm glad i do not have to take that back off... :) :)
w103pcm
I have heard water pumps are a big problem with these older engines. I pulled the sparks out; they look ok, but have some oil on them. Is that normal for these?
OBJ
I don't think the water pumps on these engines are any more troubling than others PCM. Although if I bought a used one, I would spend the extra money and put a pump kit in with housing.<br /><br />Wet plugs are OK.
