Johnson V4AL-15E Reverse Problem
carywinton
I have an old Johnson Super Sea Horse, Date unknown, probably in the 1960's. It is a 4 cylinder model V4AL-15E. I am not really sure how to properly adjust the cable and drive system to get reverse to work properly. The propeller seems to turn in the proper direction and the stick solector goes into reverse with no visible problems , but it will not pull the boat in reverse. Is this perhaps and adjustment problem or someting more serious like the clutch and gears? I could really use a parts breakdown of this engine until my service manual arrives.<br />TIA<br />carywinton
JB
Re: Johnson V4AL-15E Reverse Problem
Hi, Cary.<br /><br />Your engine is a 1963 75hp.<br /><br />Hope you ordered the right manual.<br /><br />Good luck. :)
