I have a 1984 90hp Johnson v.o.r..The trim/tilt works fine however if you hold the button for a few seconds after it has reached its max. travel either up or down, it then takes about 30 seconds of continuos button pushing before the motor starts to move again. The hydraulic pump motor is going but does not load up until about 30 secs. have elapsed. It appears as if the by pass valve is sticking for awhile, then closes off and the pump loads up and the tilt mechanism starts working again. Any help would be appreciated ..jarob New Zealand
