Johnson tilt/trim
emcgowan
I have a 140 hp Johnson outboard that has sat idle for 10-12 months. The hydraulic cylinders are leaking on the tilt/trim unit and the t/t motor may be shot. I cannot manually lift the outboard. It moves 10" or so. Is it possible that the lift cylinder is frozen? How can I get the motor up enough to get to the t/t unit?
Chris1956
Honorary Supreme Mariner
What year motor is that? The PTT units of the late 90's motors have a lower pin that holds the PTT unit. It can be driven out to allow the motor to be tilted.
flyingscott
Should be a screw on the side to allow manual operation of the t/n/t. It usually is marked on the side of the transom bracket.
