Johnson system check no oil light stays on with engine not running,VRO pump is good
rocn7roc
Hi need advise my 97 150 Johnson developed a problem. the no oil light stays on without engine running when you turn key on , The system check goes through it sequence as it should then oil light stays on engine running or not. I have hooked aux tank with oil for trouble shooting. VRO pump is working pumping fuel and oil. I have unplugged VRO 4 wire plug and light still stays on. I have unhooked oil tank 2 wire and light still stays on. Next I will check tan/yellow wire for short, then people have said if that not shorted then the tach with system check must be bad. Do these go bad. Help I am retired and can't afford taking it in. I have 30 years of mechanics under my belt and the VRO was replace a few years ago Thanks Mike
dingbat
I assume the system works off a N/O relay on the pump side. Pull the connector off fuel pump and put a meter across tan and yellow on the pump side. You should see that status change. if not, you have a bad fuel pump or fuel pump relay
rocn7roc
No it works of the crankcase pulses,uses VRO pump system counts the pulses.My light stays on without engine running the rest of fault light go out as they should thanks Mike
