Johnson starting problem
Kealob99
I have a Johnson 112 spl and the motor cranks but won’t start , and sometimes the motor will start with no problems but other times it take awhile before I can get it started, and ik theirs a leak at the carburetor but I’m just not sure what going on this is my first boat
Get the battery load tested.----Inspect the starter motor-------Post results of a compression test.------No money spent to do that testing.
F_R
Hot start or cold start??? Do you know how to start it? Seriously, are you doing the correct procedure? Tell us what exactly you are doing.
