I have a 2001 Johnson 40hp 2 cycle engine. My problem is that the starter engages the flywheel but will not disengage. I had this problem before and the shop said they rebuilt it putting in new brushes and bushings. It worked fine for awhile and now I have the same problem. But this time when I opened the starter, one of the magnets had pieces broken off. Can these be replaced? The starter still spins but will not drop back down. Is the broken magnet my only problem? Also, where are the brushes located. The model number on the starter is 586279 12 E Z. <br />Help!
