Hi Everyone,<br /><br />I have a 3 cylinder 1980 Johnson 70 Seahorse Model Number: J70ELCSA. <br /><br />My problem is that the engine regularly stalls when engaging gear. This happens when setting off (normally when surrounded by many expensive boats in the marina), in both forward and reverse and also when coming along side the marina and selecting reverse to pull the stern in; which usually results in a hard landing!<br /><br />I have had to hold the revs up on the hand throttle and then as I close that, put her into gear to get away.<br /><br />I have now turned the idle up which has worked to a certain extent; but the idle sounds much too high and quite often results in the exhaust boiling the water as the gases leave the hub of the prop. <br /><br />Does anyone have any suggestions???
