I am working on 1988 Johnson 20hp. There is no spark. I have disconnected the blakc and yellow wire to eliminate the kill circuit from being the cause. I have a fluke multi-meter and I am trying to see if I have 500 ohms from the brown wire to ground as recomended to test the stator.
I set the meter to measure ohms then I put one end in the brown wire of the power pack connector and the other end to ground but I no ohms at all.
Am I doing something wrong of is this what I would see if the stator was shot ?
