Re: Johnson short shaft to long shaft conversion
I don't think so. I think it would be easier to just add the spacer and the new drive shaft. The water tube is one thing you'll need to check, i am not sure how it is attached to the head. You may be able to replace it, if not you'll have to figure out a way to extend it. You just drop the lower unit, bolt on the spacer, swap the drive shaft, extend the tube (or see if you can swap the tube), swap the shift linkage and then re-install. If you haven't changed the impeller in a while you should drop the LU to do that anyways. I converted a OMC15hp from long to short, so same process but mine was easier cuz I just had to cut the water tube.
