Johnson Seahorse
what is it?
I was given a Johnson Seahorse motor the other day. The model is a JW-12 and the serial no is 199092. In a box that I got with the motor was what seems to be most of another disassembled motor. There was a paper in with it that said Sea Witch. On the case are numbers S 52236 and 571.14. I do not know what I have and if anyone out there can help me I would really appreciate it. Thanks.
ob
Re: Johnson Seahorse
JW12 is a 3hp 1956 model johnson outboard.The other disassembled one I am not sure of.May be a Sears or Wards outboard.What does the motor cover read?
what is it?
Thanks ob for the info. The Johnson is in real nice shape. It has good compression and spark, so I'm sure it will run. I've never really had anything to do with boats, but I think I just might give it a try. The other motor doesn't seem to have an engine cover. I'll look at it a little closer. It does have a tillotson carb.
steelespike
The 571.14 is a 41 3.5 hp.Built by Kissel(Formerly<br />an auto company) for Sears. Called Waterwitch.<br /> A fairly common motor that may be fun to try to restore. You may be able to find help at The <br />Antique Outboard Motor Club at www.aomci.com.
what is it?
A little more info here on that disassembled motor. The paper in the box said that it was a FW.837B and the serial no. is 087223. I could not however find a piece that had these numbers on it. The bore is 2 7/32 and the stroke is 2 1/4. The con rod is brass.
what is it?
Thank-you Steelespike for the info. I will look up the antique club.
