Re: Johnson Seahorse
Hello;<br />Parts in Tampa Fl., Probibly any Jiffy store!<br />I am sure you will have very little trouble finding parts for this engine in your area, most any of your local dealers should be able to help. <br />As far as losing fire, disconnect your main wire harness from the engine, use your recoil to turn the engine over. if you have fire, your problem is in most likely the ingition switch. Doing this will tell you if the problem is with the controls or with the engine.<br />If you still do not have spark, maybe you should pull the flywheel and check the points. For $20 bucks you should be able to purchase a tuneup kit Pt# 172523 & plugs, Champion J6C. Set the plugs at .030, and the points at .020 make sure to install the new condensers. Reassemble and retest. <br />If you do have to get under the flywheel take a good look at the coils, if they are drycracked, replace them now. These could also be your problem.<br />I am not aware of any kill switches on the engine. The neutral safty switch if not engaged, removes the ground from the starter selinoid, when you try to crank the engine it will not turn over. This switch has nothing to do with the spark. <br />Good Luck, Interested in seeing how things turn out.<br />Rob
