Could anyone advise how I can solve a persistent popping on this old pre-throu prop engine. The mixture screw needs to be wound out a long way before the engine will think of running properly but will then misfire in bursts. I have changed the coils and am sure it is not coils, leads or plugs, points etc. I suspected the inlet valves -but the petals seem clean and ok. Plugs run very black. One suggestion is that the seals have gone. Could this be the problem? -Rob.
