Johnson Seahorse 2.5hp
Tybalt
So, I managed to get a pair of these a few weeks back, both appear to had been military issue?? Was not aware the military would of used these, however they have US Govt decals ect. or perhaps someone put them on there to feel "special" I do not know.
What I am facing, is a lack of valuable information on these. I have managed to find a few places to get parts and such, nothing major though. But, have not found the resources or manuals on tear down and such. So I will follow with a few general questions I probably could of found within the forum, however it is snowing and my kids are itching for me to go outside.
(please note: I have owned many ATV's, Snowmobiles, Dirt bikes, cars, but never a boat nor boat motor, now we bought a house on a lake, its my sudden passion to get these things geing before spring, so my kids and family can enjoy the lake.)
How to determine the exact model and year? i.e. where and which serial numbers will I need, and where to find them?
I need to know, is this a 2 or 4 stroke engine? if 2 stroke I assume 50:1? or 32:1 ratio yes?
Where might I find a reliable service manual for these? I have no worries about tearing it down, but would prefer an "Idiot" manual prior, so I do not ruin either.
My wife said, why not get a new one? I drive a '66 Chevy, not a '08, 1st car was '68 Mustang, not a '94, my Quad is an '88, my wife's '08, I wouldn't trade it for an '09 flat out. I would much rather prefer something that is made in the USA when we took great pride in the products made here. You cannot beat a classic.
In conclusion, any information on these would be great, mostly I really need to know if it is 2 or 4 stroke, as I have one already in a tank and ready to figure out. Though if its either or, and I run incorrect fuel, its done.
JB
Re: Johnson Seahorse 2.5hp
Howdy, Tybolt.
Welcome to iboats. :)
There should be a model number on a riveted-on plate on the transom clamp, Tybalt. We need that to establish the year, most of the rest of your questions depend on the year.
Well, except the one about 2 stroke or 4 stroke. They are almost certainly 2 strokes.
samo_ott
Yes, welcome to the forum. You'll find lots of folks here with the older engines but we need the model #... Or a picture... Or both. Whereabouts are you located? I have a late 40's Johnson HD25 2.5hp but I doubt that's what you have!
Tybalt
it is a HD25, they both are, I will go get the serial and a picture in a moment. we are in Michigan.
Thanks!
Tybalt
DEP 606370
MoD HD 25
DEP 623335
MoD HD 25
Needs a touch of TLC, but i've got nothing but time until the lake thaws. Also, the 2nd pic, where the prime linkage goes into, leaks. I assume this is part of the carb, it is leaking around the center and left side rods. Repairable? If not I have another I hope to replace it with, provided I can get the necessary gaskets.
I tried to get it running, but it only sputters a bit then stalls out. Though if the carb is leaking, then the fuel flow is not proper or adequate to run anyway, so I will replace that with my extra and hope I can rebuild the leaking one for the 2nd motor.
Hope this helps ^^
JB
HD-25 was made from 1946 to 1950.
Fuel mix is 24:1.
Plugs are Champion J8C (replaces J8J) gapped at .030
Tybalt
Thanks!
I will go get plugs and fresh gas tomorrow and see if she fires. The parts that is leaking, I will just swap out with my core motor and hope for the best. 10-1 fouled plugs are why the previous owner could not get it running, and wrong mix ratio.
Tybalt
Been exciting last few months, furnace broke, 2 washers, dryer, and our van. Needless to say, tomorrow I redeck the pontoon, and finish painting the rowboat for the kids.
I changed out carbs on my lil Johnson. put in fresh gas ect, checked for leaks and all the good stuff, and she did not fire. little smoke but would not fire.
So of course I checked for spark, one plug has plenty of spark, but second plug no visible spark. so of course I did what you never want to haha, i held onto the second plug wire while my daughter pulled her over. just a little tickle, not enough voltage for a hot spark =/
Now, I got a touch of info from some people local here. And suggestion is, the plug wire is grounding out. Hopefully I can pull the flywheel tomorrow, no idea yet what to expect I have no manual, but hoping its just simply pull if off and put it back on same way when i'm finished haha
On another note, the carb I took off, float was bad, and where it leaked, it was the primer, so I assume if you "over prime" it will of course possibly leak since your putting too much fuel into it, so nothing serious I persume. The cylinders and pistons that I could see from where the carb removes, looked awesome. Very little visible wear, no gouges, nothing, they looked as though they had been recently replaced. So hoping everything withing is good.
Anyhow, I wrote a book, any possible suggestions would be great, any insight what to expect removing the flywheel would be great also.
Thanks ^^
Randall Dibble
BUUMP!
I have just joined the forum and had followed this thread.
I been given a HS-20 of 42-43 vintage.
Lookin' for more information diagnostics.
What' s the out come of the your repair.
Anyone know the torgue spec for the head bolts?
thanks
Ran
