Johnson Sea Horse 60hp..No spark
Starr
I have a Sea Horse Model VXL11A Serial: J2600644. Was running like a champ, then out of the blue sounded like it was lacking fuel, then died. After returning to shore, spark plugs were changed, basic checks were made. But still not getting any spark. Rolls over good, compression good, ect... What could be the problem?
seahorse5
Re: Johnson Sea Horse 60hp..No spark
That's an oldie with a belt driven magneto hanging on the back.<br /><br />remove the wire from the magneto to the engine harness and crank it over to check for spark. If none, then you have to check the coil, points, condensor, rotor, and cap. If it sparks, then you have a shorted "kill wire" somewhere in the system or a bad key switch.
Starr
Thank you so much for the reply, after changing the key switch, everything is in working order again. The old girl is running like new again. Thanks again..Starr
