Re: Johnson Sea Horse 10
i ran across this in my searching, do you mind if i ask a couple related questions?<br /> my recent purchase is a johnson 10 sea horse, qd 21. how do you determine the year from the 21? research on the site suggests this is 1960 vintage, but how does one calculate it? <br /> what is the spark plug gap for this engine?<br /> the current plugs are champion J6C. what is the correct gap? and are there any alternate plugs i can use? (the first store i stopped at didn't have them, and said J8C's would be fine)<br /> then i went to look at impellers in iboats, and they are all listed by part number as opposed to model and year. anybody know which impeller i need? should replacing just the impeller be ok? or should i replace the plate, bearings, etc with a water pump kit? (haven't taken it apart yet)<br /> last question; someone crossposted to a site that breaks down parts for an evinrude 10 hp sportwin, 1958. how close does this engine mimic mineas far as the schematics go? <br /> this is an awesome site! thanks
