Johnson Outboard steering pics??
Widmayer
Can someone post up some pics of Mis 80's Johnson Outboard steering, Where it connects on the Motor?
I am pretty sure I'm Missing some parts. There is one rod hooked up to the motor and it moves really sloppy.
Ant help is appreciated!!
mikesea
Re: Johnson Outboard steering pics??
It should be like a big Z shaped rod.One end goes to the cable ,the engine side should have a rotating ball ,that allows you to tighten the bolt to the engine ,tite with a lock nut on the opposite side.i have no pics ,sorry
ezmobee
Widmayer
Here is what I have, The cable doesnt mount to Anything.
ezmobee
The rod needs to go through the tilt tube on the motor. Look carefully at the picture I posted above.
