Re: Johnson Motor ID
Hi Joe,<br />Model number came from a small plate off of the mounting bracket which had both model number and serial number stamped into it. Looked like the original OMC tag. I too was confused because the tag also said 150HP but the model number translated to 130. I thought it might have to do with how the HP was measured,at the prop vs the lower unit. I had been told that prior to 83, there was some difference in the way manufacturers measured and reported HP ratings. i assumed that this may account for this difference?<br /><br />Thanks for the reply and any thoughts you may have on this.
