Johnson jw15 carb timing
Bigjim15
Hey I have a Johnson jw15 that I needs carb timing. I know when the throttle is positined between the two dots next to slow the cam lobe should be just touching and opening the butterfly valve. Mine isn't so how do I go about adjusting it I tried loosing the cam lobe but it still didn't give me enough play. thanks in advance.
Chinewalker
Work with what it'll give you - they're really not all that finicky... Close is probably close enough.
