Johnson H9497666; NO water from tell-tale
JDusza
Ensign
Hi.
I am working on a 2006 Johnson 6 hp, serial H9497666 which had been submerged.
I have the system running again but no water coming from the tell-tale hole.
The owner says water never came out of that hole.
So, my question is, should water be coming out the hole or not?
Thanks,
J
JDusza
Ensign
Re: Johnson H9497666; NO water from tell-tale
The carburetor tells me this is a 2004, not a 2006.
The only tag on the engine is H9497666. The tag indicating J6XXXX is missing.
So, are the four-strokes supposed to pee the same as the two-strokes?
Thanks,
J
JDusza
Ensign
Thought it was a simple question. ha ha ha
J
