Johnson GPX71 surging
aksparks
starts & idles fine, after aprox 6-8 sec under full power, starts surging like it is running out of fuel. back off throttle a little and runs just fine. tried different hose, primer bulb, fuel pump changed small fuel lines on carbs, different tanks. help?
P.V.
Re: Johnson GPX71 surging
What's a "GPX71"???
aksparks
GPX71 is the model on the cowl. I believe it is a 70 hp 3cyl. I have checked the venting on both tanks. The filter is clean. Is there a way to check fuel pressure near the carbs while running? If so, what should it be? thanks
papasage
am having the same probablem with my 1979 55 hp. it is usealey on the first full throttle let off a little it will run fine .changed tank new hose took the fuelpump off a motor that is running good cleaned the carbs . will keep checking back to se if anyone knowes the probablem or if i figure it out i will post it. papasage>>>>>>>>>>>>
