Hello All,
I received this outboard as a "freebie" with a boat purchase with no info about it. I am wondering what was located in the holes in the lower cowling(see picture).
Holes are numbered
1. I am guessing battery cables
2. Start button
3. This one is obvious
4. ????
Does this motor use a starter solenoid?
Spark wires were cut at the armature plate, so I am not sure I have the plug wires routed to the correct cylinders, what is the correct orientation? Does this motor use a thermostat? I pulled the thermo cover and there was nothing there.
I do have a seloc manual, but I could not seem to find the answers there. I have replaced the water pump, fuel lines, carbon ring and a few other items. Compression on the top cylinder is 110, bottom cylinder is 105, so it looks like it could be worth it to fix up.
Thanks for any help
Holes are numbered
2. Start button
4. ????
Thanks for any help
